Use this procedure to clear the Application Telemetry status counters. You can clear all of the counters or specify just the counters you want to clear by name or ID.
  1. In the navigation pane, expand Configuration > Serviceability.
  2. Select Application Telemetry.
  3. Perform one of the following actions:
    • To clear all the counters, select the Globals tab, and then select ClearCounterStats.
    • To clear specific counters, select the Counter tab, select the counter ID you want to clear, and then select ClearStats.
  4. Select Apply.
